Bevel drive Crush washer vs O-Ring
Shuswaper
Has liked: 3 times
Been liked: 11 times
Canada
Post by Shuswaper »
It has occurred to me that something might be ass backwards here. I have taken notice that in all the documents I have read so far, an O-Ring is specified for the drain plug on the Bevel housing while a crush washer is for the fill/level plug.
Shouldn't it be the other way around?
Every drain plug on every vehicle I have ever owned called for a crush washer. Seems to me, the o-ring is more appropriate for the fill/level plug where there is less chance of leakage anyways.
What say you folks ?!
Re: Bevel drive Crush washer vs O-Ring
Shuswaper wrote: Wed Oct 09, 2024 2:12 amAn O-Ring is specified for the drain plug on the Bevel housing while a crush washer is for the fill/level plug. Shouldn't it be the other way around?
No, the design of the two plugs if different.
Drain plug.
Fill plug.
Shuswaper
Has liked: 3 times
Canada
Post by Shuswaper »
Thanks for that David, haven't had to do the oil change yet, so I wasn't aware of the exact design difference in the parts !!
Cheers.
