Gents,
Looking to get a suitable very loud plug and play horn probably a single horn, to fit on my 2020 RT. My stock 2020 GT is outstanding! So I want to at least stay with a BMW part number to get the same volume this unit puts out.
Researching my other site forum member suggested part number 61 33 8 381 271 made by Clardon low tone and comes on BMW 525i car.
Found it listed on AutohasAZ.com site for $42.99.
Has anyone used this part number horn and been happy with it on their RT bike?
We need all the safety equipment we can muster for our bikes, bright lights, loud horns, top notch brake shoes and tires.....so why would BMW put a pip squeak bike horn on such a popular and expensive bike? If I was a motor officer I would never push my horn button as it is now with stock horn.
Suggestions or current horns used with satisfactory recommends greatly appreciated.
NW
2020 Stock Horn is an embarrassment on this bike!
Ninjawarrior
- Bike Model and Year: R1250 RT ,2020 BMW
- Been liked: 4 times
- Steve398
- Has liked: 584 times
- Been liked: 490 times
Re: 2020 Stock Horn is an embarrassment on this bike!
Generally it’s either Steibel or Denali, you’ll need to fit a relay to cope with the extra power draw, but at least you’ll be heard!
The high tone of the horn is (I’m told) to conform to German regulations that state motorcycle horns must be of a higher pitch than car horns.
- jesim1
- Has liked: 159 times
- Been liked: 97 times
No idea of the part number, but my 2022 R1250RT has a great horn, more like a car, I'm sure you can simply spec one of those from the dealer or go aftermarket
- Has liked: 123 times
- Been liked: 98 times
I put a Wolo in my 17RT. I sounded great, but the fender kept colliding with the horn and wiring.
I found that I had to fabricate a special bracket to move the horn further to the rear. That allowed enough clearance, so it wouldn't get hit by the fender.
- Has liked: 35 times
- Been liked: 183 times
I swapped mine to a Denali Mini Sound Bomb, and it's very loud. You do have to be careful with the fitting position if your still fitting it between the forks as the Denali horn is wider than the OEM unit, but it does clear the forks in both directions (just) if you get it right.
- Has liked: 1695 times
- Been liked: 549 times
Mine has the standard high tone buzzer horn plus a Fiamm low tone snail type. These are fitted in the area of the standard horn fixings. No relay needed as the draw is below the 10A max. Very loud set up. If you want to stay with a German set up you can buy a BOSCH 0 986 AH0 501 Horn but this produces lest at 110 decibels and draws 8A on its own, The Fiamm at 130 decibels An draws 6A
I've used Fiamm horns since my Mini days in the 80s. Each one fitted to bikes or cars have been 100% reliable.
Pannier Down
- Bike Model and Year: 2014 R1200RT LC
- Has liked: 9 times
- Been liked: 6 times
I added the 5 series horn and although the tone was lower, it didn't really sound any louder to me.
djk63
- Bike Model and Year: 2024 R1250RT
I don’t know if the stock horn for a 2024 RT is plug and play but would be worth checking. The horn in mine is almost as loud as the horn on my truck. My wife almost jumped out of her skin the first time she heard it!
