Spare blank Power socket front near side
carrollthomas
Bike Model and Year: BMW R1250 RT 2019
Post by carrollthomas »
Hi, does anyone know what this socket is for, it is located under the front fairing under the near side mirror, there are 3 cables going into it but the socket is blank on the inside and no pins are visible
2023-02-02 15.32.23.jpg (295.22 KiB) Viewed 19104 times
2023-02-02 15.32.17.jpg (208.64 KiB) Viewed 19104 times
Re: Spare blank Power socket front near side
Probably for the auxiliary lights :)
carrollthomas
I was thinking it was an AUX port but why would the internal of the socket have no pins to connect to, you can see the cables going into it but nothing on the inside...
The cap/blanking cover needs to be removed from the plug/socket to expose the pins.
As David says you will need to remove the blanking cover then it will connect to all the wiring for the AUX lights
It plugs in to the wiring connector just under number 9
Screenshot 2023-02-02 223657.png (137.35 KiB) Viewed 19072 times
C.farmer12@btinternet.com
Bike Model and Year: 2018 r1200rt
Post by C.farmer12@btinternet.com »
What age is that bike?
I am searching for somewhere to plug in my nippy Normans cable for tomtom but cannot find a plug on my 2018
C.farmer12@btinternet.com wrote: Sun Feb 19, 2023 11:20 amI am searching for somewhere to plug in my Nippy Normans cable for Tom Tom but cannot find a plug on my 2018.
Quote from NN,
"the connector on the R1200RT LC is located in the area behind the meter panel. Need to remove windshield and a panel behind it to access."
https://www.nippynormans.com/gps-access ... mw-harness
C.farmer12@btinternet.com wrote: Sun Feb 19, 2023 11:20 am What age is that bike?
Take screen off and the panel underneath,as you stand in front of the bike the plug your looking for is to the right(presume its the same as my 16)Near the top :thumb:
billy_bmw
Greece
Post by billy_bmw »
Thanks For the info
I took 12v power from it and installed a qi stand-charger for my waterproof mobile-GPS (Google maps)
Here are the 2 products you need.
https://motokinisi.gr/gr/bash-kinhtoy-g ... 07535.html
https://www.interphone.com/en-it/Holder ... TOWIRELESS
HPTCC!
Australia
Post by HPTCC! »
Hi. I hope this is the right place to ask this question. I have taken delivery of a new 2024 R1250RT. I read that the bikes have this spare power socket located between the handlebars and the left side mirror. Some use it for satnav. For those owners here in Australia, do our bikes have this cable ? If so could I use it to power my iPhone ? Any help appreciated. Have a safe Christmas/New Year.
HPTCC!
Australia
Post by HPTCC! »
Another question. Has anyone drilled or considered drilling a small hole into the phone cubby so that the USB could be used to power an iPhone mounted on the handlebars ?
HPTCC! wrote: Wed Dec 25, 2024 10:36 pmI read that the bikes have this spare power socket located between the handlebars and the left side mirror. Some use it for satnav.
Your motorcycle may be the same as this one.
HPTCC!
Australia
Post by HPTCC! »
Hi David. Thanks for your reply. Much appreciated. I hope so but I know that specs can vary depending on which country the bike is in. I had a look in that area but I couldn't see it. It may be well hidden of course. Looks like another question for the dealer. Cheers.
