Skene Lights may provide a solution, https://skenelights.com/Strat Tuner wrote: Tue Dec 24, 2024 10:28 pmThe Brake light Flashing chip I like most won't work with the BMW system.
Compatible, https://skenelights.com/compatible.html
In the above video, the resistor if fitted in parallel close to the bulb holder.Strat Tuner wrote: Tue Dec 31, 2024 2:21 amMaybe you mean put a resistor as close as possible to each bulb.
Math and I are lifelong enemies and we are barely on speaking terms. I confess I don't understand your answer much at all... Shouldn't two bulbs, wired in sequence, give DOUBLE the resistance of ONE bulb?David. wrote: Tue Dec 31, 2024 7:19 am When two resistors (bulbs) of the same resistance are wired in parallel, the equivalent resistance is half the value of one of the two resistors.
Using the two 6.86 ohm bulbs as an example, the equivalent resistance is 3.43 ohms.
1/Rt = 1/R1 + 1/R2,
1/6.86 + 1/6.86 = 2/6.86,
So, Rt/1 = 6.86/2 = 3.43 ohms.
However, two LEDs of less resistance than the filament bulbs won't work. Hence the need to fit additional resistors with the LED bulbs.
If the two bulbs are wired in series (sequence), then yes, the resistance will be double that of one bulb.Strat Tuner wrote: Wed Jan 01, 2025 10:28 pmShouldn't two bulbs, wired in sequence, give double the resistance of one bulb.
As per the video, with a "super fussy vehicle", sometimes a CAN-bus error free bulb with a resistor built in doesn't cut it and an additional resistor is required to be fitted.Strat Tuner wrote: Wed Jan 01, 2025 10:28 pmThe bulbs I'm using are the "Canbus erorr free" variety that come with the resistor built in to the bulb.
If they work as advertised, then both of the LEDs together should resist the same as two filament bulbs.... but they don't.
It looks like BMW themselves may be able to supply a "plug & play" Supplemental LED Brake Light.Strat Tuner wrote: Tue Dec 31, 2024 2:44 amI've given up on getting the brake light to flash on braking.
