SOLD - As it says this is Givi USB Power Supply Hub that will give you 3x USB ports with a total of 6600 mA (3 x 2200 mA), AND a fourth device with the ISO 12v Inner Power connector The External wiring kit is fully waterproof, but please note the hub is not so needs to be fitted inside a tank bag, top box or similar 'dry' location. Give sell what I have as two separate parts:-
1. The Power Hub - Givi S111. This is the rectangular power hub with 3x USB sockets & 12v outlet. It connects to a waterproof connector which can be fitted inside with a tank bag, top box or similar.
2 The Power Supply - Givi S110. This connects to your battery and the waterproof connector.
There is cable end cap missing (which I've highlighted on photo 06), but this doesn't affect funtionality and I've put a new piece of self adhesive ro the one half of the velcro, but I'd recommend you use some proper glue anyway.
See:-
https://www.givi.co.uk/givi-products/sm ... -power-hub
https://www.adventurebikeshop.co.uk/ele ... power-hub/
https://www.adventurebikeshop.co.uk/ele ... onnection/
£45.00 Incl P&P or £40.00 and a cuppa if we met up somewhere in the Welsh Marches.
Givi S111 & S110 Electrical Power Hub & Power Supply Cable
- Has liked: 35 times
- Been liked: 183 times
- Givi Power Hub (01).jpg (149.92 KiB) Viewed 7475 times
- Givi Power Hub (02).jpg (119.64 KiB) Viewed 7475 times
- Givi Power Hub (03).jpg (200.25 KiB) Viewed 7475 times
- Givi Power Hub (04).jpg (187.4 KiB) Viewed 7475 times
- Givi Power Hub (05).jpg (178.89 KiB) Viewed 7475 times
- Givi Power Hub (06).jpg (69.54 KiB) Viewed 7475 times
Re: Givi S111 & S110 Electrical Power Hub & Power Supply Cable
Hi, don’t suppose you still have this ?
Actually I do. Still in the that'll be useful one day box.
Wow that’s amazing, are you still looking to sell mate?
