I have traded my R1250RT fora R1300RT so have for sale my panniers bags & top box bag.
2 zip pulls are slightly damaged on one of the -pannier bags as per the photos, this doesn’t affect the functionality of the bag.
The side panniers expand.
I purchased them new £60.
Selling uk only £30 plus postage.
Material: Heavy-duty 600 x 600 Denier Polyester Vinyl Laminated PVC materials is used to make these bags durable and sturdy.
Lightweight: although these pannier bags for BMW R1250RT are lightweight but can carry enough weight.
Easy use: Liner bags are custom designed to utilise maximum space and fit perfectly inside the pannier bags.All 3 bags can be opened like a suit case for easy use.
Water-resistant: water-resistant material ensures great resistance for a maximum time.
Visibility in the dark: reflective piping is used on the outer lining to make these bags more visible in the dark.
Strong piping: due to strong piping these bags these bags for BMW R1250RT panniers stays in shape and are not vulnerable to ripping off as well.
Stitching: heavy-duty nylon thread is used for stitching that improves firmness.
Super quality zippers: High-quality zippers add smoothness and don’t stick while opening and closing the bag.
Shoulder Straps:shoulder straps make it easy to carry these bags.
Outer pocket: an outer pocket is placed for putting important travel documents and maps.
Bottom studs: bottom studs prevent liner bags from dirt and cuts. You can place it on any surface.
Easily stored: You can easily flat-pack and store these bags for future use.
Pannier & Top Box Liner Inner Bags R1250RT & K1600
220e
- Bike Model and Year: R1300RT LE ASA 2025
- IMG_1026.png (933.83 KiB) Viewed 716 times
- IMG_0293.jpeg (389.59 KiB) Viewed 716 times
- IMG_0294.jpeg (368.29 KiB) Viewed 716 times
- IMG_1027.jpeg (473.77 KiB) Viewed 716 times
- IMG_1028.jpeg (368.07 KiB) Viewed 716 times
- IMG_1029.jpeg (427.76 KiB) Viewed 716 times
- IMG_1030.jpeg (140.33 KiB) Viewed 716 times
- IMG_1031.jpeg (221.28 KiB) Viewed 716 times
