Anyone tell me how to make one of these. Thinking all I need is a pipe with with a large thick washer at the end and a threaded bolt into the handlebar end. Working on 2021 r1250rt
Handlebar puller
Strop
- Has liked: 1 time
Re: Handlebar puller
Used this guide to help remove the switch gear.
The small tourque tool size is T5.
Had to sand a bit of paint off and throw the bars into the freezer to get them to fit into the new risers.
Strop
- Has liked: 1 time
Some photos . The only downside in relation to where they are currently placed is that I can not rotate the front brake lever as far forward(down) as U would like. Hits the risers. I have set the risers up so they come back towards me a bit as well. If I was to make them straight up I don’t believe this would be an issue. Only time will tell.
- IMG_0526.jpeg (556.02 KiB) Viewed 6509 times
- IMG_0527.jpeg (764.86 KiB) Viewed 6509 times
- IMG_0536.jpeg (447.24 KiB) Viewed 6509 times
- IMG_0537.jpeg (424.89 KiB) Viewed 6509 times
Strop
- Has liked: 1 time
I made the tool very cheaply. 25.4mm pipe - was only 1.2mm thick. Like a curtain rod. Cut it to length - found a couple of washers and bought some bolts as I didn’t have a correct size one.
Switch gear removed and pipe slides over bar. Bolt pulls it out. I had a couple of spare washers which was handy because they got bent on each bar. Put some tape over bar so no scratches.
I got the risers from Ali express - seem ok to date.
- Been liked: 560 times
You can rent the tool from Sportouring,painless experience and very helpful.
https://www.google.com/url?sa=t&source= ... uovOsOP7oM
