Warm up Engine for 2 to 5 minutes
cdnrtowner
Post by cdnrtowner »
When I purchased my 1200 RT, the sales manager told me that it was important to "warm up the engine for 2-5 minutes before driving." With fuel engine and computerized control of fuel and air, I believe that any warm up period exceeding 1 minute was not necessary. Idling the engine is not a good thing. What is your advice regarding " warm up time?" :-\
cdnrtowner
Re: Warm up Engine for 2 to 5 minutes
I have just checked the 2013 Owners Manual which states "Ride away immediately
after starting the engine."
You were told rubbish.  Press button, go.
Peter Baker
Has liked: 14 times
Been liked: 7 times
Post by Peter Baker »
RTman10 wrote: You were told rubbish. Press button, go.
+1 agreed!  Peter
smileymiley
Has liked: 6 times
Been liked: 11 times
Post by smileymiley »
+1
realshelby
Post by realshelby »
Find another service manager! What else is he ignorant about?
cdnrtowner
It is unanimous; ride away after you start the engine. Thanks for all your help/advice. Cheers.
guest3074
Post by guest3074 »
Mine runs for as long as it takes me to put my lid and gloves on  :)
Alf170
Post by Alf170 »
Only warm up needed is the Satnav to locate satellites. After that, button pressed and go have fun.
JayBees7
Post by JayBees7 »
You wisely chose this bike and then took advice from a sales manager. ?? Oops.
guest2826
Post by guest2826 »
And another vote - complete rubbish.
Having said that, there are bikes which do need it so perhaps the advice given was confused by that. I had a modern Guzzi V7 not long ago and that definitely needed a short idle period to warm up if starting from cold or it was likely to stall when setting off. Nowhere near as long as 2-3 minutes though, perhaps 15-30 seconds or so.
Also, in the "old days" of Beezas, Triumphs, Nortons etc, this was common practice.
Vince Prince
Post by Vince Prince »
cdnrtowner wrote: When I purchased my 1200 RT, the sales manager told me that it was important to "warm up the engine for 2-5 minutes before driving." With fuel engine and computerized control of fuel and air, I believe that any warm up period exceeding 1 minute was not necessary. Idling the engine is not a good thing. What is your advice regarding " warm up time?" :-\
Good advice... if you're riding an RS 125/250 two stroke. You don't want a cold seizure ;) . Four stroke, start em and ride em. Maybe your sales guy once worked for Aprillia.
T6pilot
Post by T6pilot »
Start the bike, put my gloves and lid on, ride away slowly till I see temp coming up
Then have at it
When it's very cold out, below freezing, I will let it idle for a couple minutes, hoping the seat and grips warm up a bit😎
