Main display change to speedo?
PatriotBMW
Post by PatriotBMW »
2014 RT - I've read the manual, and changed user background to speedo- but it still only shows the current radio song.  How do I change the master screen setting so it shows the speedo?  If I mess with the wheel it only changes volume up/down, or previous/next track.  Advice appreciated!
2014 R1200RT
T6pilot
Re: Main display change to speedo?
Post by T6pilot »
I believe radio must be off
smileymiley
Has liked: 6 times
Been liked: 11 times
Post by smileymiley »
T6pilot wrote: I believe radio must be off
That is correct
You can have either the digital speedo or the audio unit showing but not both at the same time It's been like that since 2012 when it first appeared on the 1600.
kiki
Post by kiki »
And by the way, to turn the radio off you have to hold the power button (on the side fairing) . If you just press it once it mutes it, but doesn't turn it off.
Paggers
Post by Paggers »
That was one of my minor gripes when I got my RT - the fact that if I have the audio system on it 'takes over' the central screen. But once I knew there was nothing I could do about it I soon got over it.
My Nav V shows my current speed and I'm used to looking at that from the GS anyway so I am not finding it a big deal.
PatriotBMW
Thanks guys, I didn't realize the audio had to be off.
2014 R1200RT
Been liked: 46 times
Paggers wrote: That was one of my minor gripes when I got my RT - the fact that if I have the audio system on it 'takes over' the central screen. But once I knew there was nothing I could do about it I soon got over it.
I like the digital speedo, but that is no more accurate than the analogue one. The only accurate speed is displayed on the Nav V or whatever GPS you are using. Think most speedos over read.
BeeJay
Post by BeeJay »
In my experience most speedos over-read.
My RT is not bad but my Pan over read 5mpk at 70mph
BeeJay wrote: In my experience most speedos over-read.
Yeh meant over read  8)  I'll edit my post
BeeJay
Post by BeeJay »
And I meant mph not mpk
Oops
One of the advantages of not having the audio unit.  Digital  Speedo and music at the same time via the Nav.
Paggers
Post by Paggers »
Vehicle speedometers will always over-read slightly. That's because if they under-read then the manufacturer would be liable for people breaking the law. So they play it on the safe side (who can blame them). My RT under-reads by around 2 mph, compared with my 5-series which is by 3 mph. What I find interesting is that it is consistent across the speed range. Which means that BMW are most likely reading the speed correctly then adding the small modifier to keep themselves comfortably within the law.
RTman10 wrote: One of the advantages of not having the audio unit.  Digital  Speedo and music at the same time via the Nav.
That's all very well - but how do you listen to Steve Wright in the Afternoon?
Think thats an advantage of not having audio!
