Has anyone mounted a cell phone holder (I have an iPhone 7) fo the 2015 R1200RT? I saw one today where the base plate for the mount, bolts on top of the Brake reservoir. If you have successfully mounted a cell phone holder to the 2015 1200 RT can you tell me which mount you bought and where it mounts?
Thanks in advance
Cell phone mount for a 2015 R1200RT
Re: Cell phone mount for a 2015 R1200RT
I have a 2017 RT. This is what I use for my IPhone 6SPlus . The phone twists on and locks securely. There are other similar systems. I use a cable from the front accessory socket for power through a dual usb socket. I also bought a braided charging cable with a 90o connector.
There are many many ways to do what you wish but this works for me.[emoji3]
Interesting set up, thanks. Does the BMW emblem just pop off? How is the mount secured to the handle bar?
The BMW logo pops out / levers of its hole, there are a couple of securing lugs. The ram ball comes with a long screw which you hand rotate into the hole.5 mins max job.Rwslater wrote: Interesting set up, thanks. Does the BMW emblem just pop off? How is the mount secured to the handle bar?
Do you happen to have a part number??? I REALLY like that position and I can't find it anywhere here in the states or even over seas.
Kabish wrote: Do you happen to have a part number??? I REALLY like that position and I can't find it anywhere here in the states or even over seas.
https://www.nippynormans.com/gps-access ... r1200rs-lc
I have the mob armor, it's nice but I have Illium risers to clamp it to, I had to modify the clamp when I used it without the risers, ground the clamp a little narrower. I can pop it off and use it on my other bikes or my bicycle. It fits my iPhone 7+ and will take a bigger or smaller phone.
https://www.amazon.com/Mob-Armor-Switch-Claw-Large/dp/B07BB5LXM9/ref=asc_df_B07BB5LXM9/?tag=hyprod-20&linkCode=df0&hvadid=309778870288&hvpos=1o2&hvnetw=g&hvrand=1901849230327927912&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9032531&hvtargid=pla-598524563724&psc=1
