Clutch master cylinder failure
Palegs
Post by Palegs »
I have a 2010 R1200RT with 53k km on the odo. On my last trip my clutch started to fail. When I pull the handle to the bar and keep it there for 5-10 seconds, the clutch will start to engage again. No problem under normal gear shifts, only when i keep the clutch handle against the bar. There are no leaks from the slave cylinder, and the reservoir is full. I am suspecting bad seals in the master piston. I have tried to search for clutch information but it seems hard to find. Service an repair manuals I have read are not comprehensive on the subject. I think that you could get a master cylinder replace kit on earlier RT models, but not for the 2010?
Is the master cylinder Brembo or Magura? I believe Mag, but not certain. My reservoir is of the wobbly, transparent, plastic type. What is the diameter of the master cylinder? I believe 13mm, same as the R12000GS from the same production period?
There is a youtube video showing how to replace seals on a R1200GS, with seals from a 13mm replacement piston from a KTM (magura). You keep the original piston an just swap the seals. Anybody tried this with a 2010 RT?
Any help on the subject is appreciated!
Our Gee
Been liked: 34 times
Re: Clutch master cylinder failure
Post by Our Gee »
If you look at the Maintenance section you will find that there is quite a lot of info pertaining to your query.
"Clutch Master Cylinder Re- Build" and "Clutch Slave Cylinder"
I myself have recently carried out a Master Cylinder "Seal" change using the info from these posts.
Our Gee
Post by Our Gee »
Come on then, Palegs a response would be nice.
