Fairing catches
Fairing catches
Taken side fairing off, the piece with the silver bmw badge and 1200rt badge on.
It should attach near where the radio buttons are but there seems to be two
Small pieces of plastic snapped
Off, has anyone had this problem and how did you get over it
Re: Fairing catches
Oly wrote: Taken side fairing off, the piece with the silver bmw badge and 1200rt badge on.
Yep well know problem. I think you can buy a repair kit. But I have repaired quite a few by making some ali tabs and just glueing them on with JB Weld. Do a search on bmwlt.com and possibly on here for tab repairs
- 60Aviator
- Bike Model and Year: 2017 GSA & 2021 R1250RT
- Has liked: 8 times
- Been liked: 14 times
Re: Fairing catches
Clearwater Lights makes a clip replacement kit.
- Been liked: 380 times
Re: Fairing catches
And I've just ordered some,the postage to the UK is bloody steep60Aviator wrote: Clearwater Lights makes a clip replacement kit.
Re: Fairing catches
My glueing method with ali/tin tabs has lasted 6 years on one bike, so there are plenty of diy solutions
Re: Fairing catches
I'd give it a go but I'd only bugger it up,and all 4 are busted.Casbar wrote: My glueing method with ali/tin tabs has lasted 6 years on one bike, so there are plenty of diy solutions
Re: Fairing catches
The clips turned up today.Have to say,the they are solid.Shame these can't be found over here,because the postage is bloody steep(buyers choice i spose)I'm going to be very busy next weekend sorting all the stuff I've bought for the bike.
[size=2px]
[/size]
[size=2px]
[/size]
[size=2px]
[/size]
[size=2px]
[size=2px]
[/size]
[size=2px]
Re: Fairing catches
Got the tabs on both panels, solid piece of metal so should do the job for a few years.When i originally broke the tabs i tried to glue them back on which was never going to work.Now the new tabs are on i see how you could knock some up out of ally and save yaself some cash.
[size=2px]
[/size]
[size=2px]
[/size]
[size=2px]Anyhoo job done.[/size]
[size=2px]
[size=2px]
[/size]
Re: Fairing catches
I'm having to do this again due to not using the correct glue,this time round I need to put the velcro that BMW have used on other bikes,anyone have a link to the stuff they use,thanks.
Re: Fairing catches
Mk2 attempt-
If need be I'll sand it after I've offered it up to the bike.Managed to track down what BMW use,so that will be going on when I finally get them on.Better stay put this bloody time
- EasyRider
- Has liked: 144 times
- Been liked: 345 times
Re: Fairing catches
Its looking good, But did you key the ABS plastic with 800 grit wet n dry ?
- EasyRider
Re: Fairing catches
OK,
I've repaired many ABS motorcycle panels. Having a good key and getting it very clean are what you need for a good bond.
I was thinking about them tabs you are fitting the other day. If it was mine i would of drilled some small holes in the tab so the JB weld pushed though them to help with the bonding. I degrease everthing as well with panel wipe.
