Hi all.
I have a question regarding torque for front and rear calipers on the 2021 1250.
I search internet for answers, but they are kind of mixed.
So far for front I found as follow:
28Nm
30Nm
38Nm
The last one if from Boxflyer torque sheet for this specific model.
Anyone have any idea which one is correct?
And for rear is pretty similar situation, found few of them too.
1250 Caliper bolt torque
- Been liked: 480 times
Re: 1250 Caliper bolt torque
The BMW Rider's Manual says 38Nm for the front caliper bolts, can't see a value for the rear caliper bolts.
The front is given because the caliper needs to be removed to remove the wheel, whereas, this is not required for the rear wheel.
If there is any doubt, just ring your local friendly BMW dealer.
- Arek
- Has liked: 5 times
- Been liked: 10 times
- Contact:
Thank you guys. I used the sheet provided by @Boxflyer (thanks again for sharing it).
Replaced done yesterday. OEM swapped for dedicated Brembo pads. I was very surprised, OEM pads still had quite a bit to "the end", however I decided to replace it anyway. I was surprised because I've been in Alps and Dolomites for over 10 days. So I suspected my brake pads will be on limit, especially I have them from factory, so two years now. About 14K miles. And they was not.
Front callipers bolts mounted without thread locker, but with small amount of copper grease. I never took them off, neither BMW garage for my knowledge, so I assume that's factory. Used touch of copper too when mounted back.
Rear calliper pads replacement are easier, but cleaning without taking off calliper is kind of challenge. Hover that done as well.
