T-rex crash bars
Trappistmonk
Bike Model and Year: 2023 R 1250 RT
T-rex crash bars
Post by Trappistmonk »
Hi
I just received my new to me 2023 RT and I am looking at crash bars. I have Ilium on order, but found the T-rex bars. I was comparing mountain points, as I feel that more mountain points, prevent the bars to flex or move with a tip over or slow speed slide. Material wise, they both use 1 inch steel.
T-rex fromt: 3 connection points
T-rex back: 4 connection points
Ilium: back and front, 2 connection points
I know you can remove the ilium rears, but I doubt I would ever do that.
Can you easily do an oil change with the T-rex bars installed just like the Ilium?
Does anyone had the misfortune of dropping their bike with the T-Rex crash bars installed and can you share your experience?
Re: T-rex crash bars
Have you a link to the T Rex bars? I only thought they did stuff for adventure bikes
Trappistmonk
A good price. Heard good reports on their kit on YT
Trappistmonk
Yes, I canceled my ilium works and will be installing these at half the price. I’ll have to see how the clamping to the silver frame for the swingarm will work. I hope it will not scratch or damage that.
You'll be fine. If worried try some low tack painters tape
washburn72
Bike Model and Year: 2008 R1200RT
Post by washburn72 »
I'm very happy with the T-Rex bars on my '08. They were fairly easy to install and I believe they will hold up well in the event of a tip over. Oil change is easy, as the front bars have a provision to take off a section of the bar to access the oil fill. Works really slick! Highly recommend them!
Trappistmonk
Quick update as I received the crashbars. In hindsight I should have kept my ilium works order as the welding and powder coating quality looks rough. One of the plates was damaged, so I assume they will send me a new one.
Some picture so you can see weld quality. I will update more after install.
1gewehr
Has liked: 8 times
Been liked: 40 times
Post by 1gewehr »
That's rough! Even my welds look better than that!
