Large Bolt through swinging arm
BacktoBeemer
Bike Model and Year: rT1200.2008
Post by BacktoBeemer »
Hi,the above bolt that holds the rod on top of the swing arm/ drive shaft tunnel (sorry for my ignorance obviously I love riding my bike but don’t know what makes it work ! :lol: )
Is very rusty and I’d like to replace it as it spoils my silver swing arm ! The rest of my bike is spotless really,it’s a 2008 Hexhead with 13000 miles under its belt .
If I undo this bolt I presume the swinging arm will drop down or worse and I’m afraid of causing more damage than it’s worth.
Any advice/ help appreciated.
Again,please excuse my ignorance :cry:
MarkW
Bike Model and Year: R1200RT 2012
Been liked: 6 times
Re: Large Bolt through swinging arm
Post by MarkW »
If i understand you correctly the item you refer to is the paralever arm (BMW call it a "tension strut") and it controls the movement in that big joint where the swingarm meets the bevel drive.
This bit: https://www.realoem.com/bmw/enUS/showpa ... Id=33_1225
You will need to remove the rear wheel to access the 2 screws holding the black plastic cover on, then put something under the bevel drive (often referred to as the "diff" - which it isn't) to stop it dropping when you remove the arm.
This is an ideal opportunity to grease the splines where the driveshaft meets the rear bevel drive _ an oft neglected but simple bit of essential maintenance ;)
