Bagster tank cover
owl
Has liked: 17 times
Been liked: 51 times
Bagster tank cover
Post by owl »
I've always fitted Bagster tank covers on my bikes, and I've just bought one for my 2019 R1250RT.
I've just fitted it. I had no problems locating where the rearmost straps had to fit, or the middle ones or the one that goes round the headstock, but there are two forward facing fixings at the front of the cover, with very long straps, & I can't for the life of me figure out where they are supposed to go. To be honest, they seem somewhat superfluous as the cover fits nice and flat without them, and seems secure enough.
The bag arrived with no fitting instructions & I can't find anything on the Bagster site, Youtube or the internet in general.
Has anyone here fitted a Bagster tank cover to their bike?
Re: Bagster tank cover
Panman40 has the same bike as you and fitted a Baglux tank cover to it. I’ve alerted him to your post.
owl
Has liked: 17 times
Post by owl »
Thanks Steve - I've just done that :cheers:
Has liked: 773 times
Been liked: 143 times
owl wrote: Fri Mar 06, 2026 10:34 am I've always fitted Bagster tank covers on my bikes, and I've just bought one for my 2019 R1250RT.
Hi Tom,
If you’ve not sorted those straps already took off the front side panels and fed the straps through to a convenient torx bolt, I made a hole in the strap and secured it that way under a little tension, once fixed in place I cut off the excess strap.
If I get chance later today I will pop off a fairing and take a picture if you need one. It’s been a while since I removed that panel though!.
Martin.
As Panman said,if they are the same as the Bagster for the 16 plate 1200.The long straps feed through the tiny gap in the panels to the inner panel.Down past the rads,find a convenient bolt,make a hole and fix it in(hope that makes sense)
owl
Has liked: 17 times
Post by owl »
Thanks both. Seems to be a lot of trouble to go to though?
I took the bike out for a short run yesterday, maybe 20 miles or so, and there was no discernible movement on the Bagster without the long straps being fitted.
Tempted to leave it as is, but on the other hand, I have this little ear worm nagging away at me that says they're there for a purpose.
A picture would be very helpful, Martin, if you can be bothered.
owl
Has liked: 17 times
Post by owl »
Just for info, these are the fixings that I haven't connected the straps to. As you can see, the tank bag is laying flat and seems secure enough?
The straps are each about 2' 6" long.
owl wrote: Sat Mar 07, 2026 10:48 am Just for info, these are the fixings that I haven't connected the straps to. As you can see, the tank bag is laying flat and seems secure enough?
Hi, I’m sorry I haven’t gotten around to taking tge panel off yet, unexpected errands and chores, I just took a quick snap of where I fed the strap though, if you pop the side panel off there’s a couple of torx fixing points .
Panmans is the same way I fitted mine :thumb:
owl
Has liked: 17 times
Post by owl »
Thanks for the photo, Martin - most helpful - at least I can now see exactly what you were talking about.
I've never taken those panels off before, I will have a go as soon as I can.
owl wrote: Sat Mar 07, 2026 2:36 pm Thanks for the photo, Martin - most helpful - at least I can now see exactly what you were talking about.
It’s been a while since I’ve taken one off, it’s a fairly quick job but there’s some Velcro plus 2 tiny tabs along the top you need to take care not to break, if you do a quick google I’m sure there’s a few videos that will show you.
owl
Has liked: 17 times
Post by owl »
Thanks for the tip - I'll have a look online.
I managed to feed the straps through without taking the side panels off.They come out either side of the horn(if I remember correctly) once you have them through you can coax them into place by pulling either end and working it into position.Don't bust them tabs,it's a pain replacing them,ask me how I know :lol:
owl
Has liked: 17 times
Post by owl »
That sounds brilliant. I'm not noted for finesse. I'm more of a "Bollocks - hit it with a hammer" kinda bloke.
burridge01 wrote: Sat Mar 07, 2026 6:30 pm I managed to feed the straps through without taking the side panels off.They come out either side of the horn(if I remember correctly) once you have them through you can coax them into place by pulling either end and working it into position.Don't bust them tabs,it's a pain replacing them,ask me how I know :lol:
I suffer with ocd so I had to find the best possible place to fix those straps :lol:
