GS911 for bleeding the abs pump ?
Has liked: 773 times
Been liked: 143 times
Has anyone used the gs911 to perform the brake fluid change / bleed the abs pump on a 2019 R1250rt or similar ?.
I was thinking of just booking it in somewhere to get this done but I have nowhere near me that’s any good :roll: .
As I have a gs911 I thought I’d give it a go, is it easy ?, is there a guide somewhere maybe ?.
Re: GS911 for bleeding the abs pump ?
Yes I have done it on my 2016 and it's easy
Although what's the reason for wanting to do it? I later found out that you don't need to do it to bleed the brakes ad it's only really there is it's to be filled up from dry as the fluid goes through the abs pump anyway and flushes the old fluid out
Reason for wanting to do it is part of home servicing, I wasn’t aware just bleeding the brakes conventionally the abs pump would be purged of old fluid, I don’t think I’ve been in a scenario where the abs has activated out on the road.
That's the reason I did it too but I since read it's not required
I will try and find the documentation with the info to put your mind at rest
Stu wrote: Fri Mar 14, 2025 11:14 pm That's the reason I did it too but I since read it's not required
A couple of questions :-D
Did you have both reservoirs full of new fluid ?,
Reservoir caps on ?,
After bleeding the pump was there more or less fluid in the reservoirs?.
Cheers.
Panman40 wrote: Sat Mar 15, 2025 5:32 am A couple of questions :-D
Cheers.
Caps off, full of fluid and some fluid come out but not a great deal
Here is the procedure for bleeding the brakes and at no point in any of it does it say to activate the ABS pump.
Brake Bleeding.pdf
(3.68 MiB) Downloaded 233 times
I did it thinking I had to but not sure it was really needed but I suppose it makes no difference if you have the GS-911 to do it then theres no harm really
Stu wrote: Sat Mar 15, 2025 8:18 am Caps off, full of fluid and some fluid come out but not a great deal
Brake Bleeding.pdf
Thanks for the pdf Stu, when you say some fluid came out do you mean it spilled out the reservoirs ?.
I’ll probably just change the fluid, I was looking at those stainless steel easi bleed nipples . Do you know if you just leave them in afterwards ?.
Out of the bleed nipple
You can get easibleed nipples that you do leave on the bike but I just prefer the old fashioned way
@15RTSteve
Post by @15RTSteve »
I have a 2105 and bought the BMW Service Manual CD when I purchased the bike 4 years ago. The procedure in the FSM does not mention "bleeding the ABS pump". The downloadable PDF in the previous post is from the FSM.
Well I’ve got 500ml of bmw brake fluid, genuine oil filter, sump washer and the 2 washers or a final drive fluid change coming from BMW for £26.04. Ordered 5L of the S&M 5w/40 at £28.99 so a fairly respectable price for a small home service.
Oh and just ordered a one way valve brake bleeder for £4.
I’ll refer to the pdf for bleeding the brakes.
