Valve cover leak
WingWheel7
- Bike Model and Year: 2012 rt 1200
- Been liked: 2 times
Valve cover leak
I’ve got a leak from right side valve cover. I’ve replaced the gasket with a new one. I believe previous owner replaced valve cover with aftermarket one since there isn’t a bmw part number on the inside. I’m out of ideas. Not sure what else to do.
- IMG_0873.jpeg (216.34 KiB) Viewed 793 times
- IMG_0872.jpeg (275.67 KiB) Viewed 793 times
WingWheel7
Mark S.
- Bike Model and Year: RT1250RT 2021
- Has liked: 7 times
- Been liked: 4 times
Re: Valve cover leak
The reason I ask is because certain types of material tends to stick to the mating surfaces. Anything on the mating surfaces can prevent a seal.
WingWheel7
ajaycad66
- Bike Model and Year: 2012 R1200RT
- Been liked: 3 times
Check for any "warpage" of the head cover. Aftermarket covers wont be up to OEM standards I would suggest, and could warp with the heating/cooling process.
Lay the cover on a piece of glass, (or a known flat surface) then use a feeler gauge to see if there is any difference between the glass and mating surface along its length.
This will hopefully indicate where the source of the leak is.
