Valve cover leak
WingWheel7
Bike Model and Year: 2012 rt 1200
Valve cover leak
Post by WingWheel7 »
I’ve got a leak from right side valve cover. I’ve replaced the gasket with a new one. I believe previous owner replaced valve cover with aftermarket one since there isn’t a bmw part number on the inside. I’m out of ideas. Not sure what else to do.
Mark S.
Bike Model and Year: RT1250RT 2021
Has liked: 7 times
Been liked: 4 times
Re: Valve cover leak
Post by Mark S. »
What kind of gasket material?
WingWheel7
Gasket was bought from Max BMW. I assume it’s the factory gasket.
Mark S.
Has liked: 7 times
Been liked: 4 times
Post by Mark S. »
The reason I ask is because certain types of material tends to stick to the mating surfaces. Anything on the mating surfaces can prevent a seal.
WingWheel7
I cleaned both surfaces thoroughly
ajaycad66
Bike Model and Year: 2012 R1200RT
Post by ajaycad66 »
Check for any "warpage" of the head cover. Aftermarket covers wont be up to OEM standards I would suggest, and could warp with the heating/cooling process.
Lay the cover on a piece of glass, (or a known flat surface) then use a feeler gauge to see if there is any difference between the glass and mating surface along its length.
This will hopefully indicate where the source of the leak is.
