I'd like to change the Final Drive Oil. I do this on the Yamaha FJR, and it's obvious how it's done.
It's NOT Obvious on the BMW.
The following pic shows where the drain is, and where the red circle is, where the oil "input" should be.... but it's not!
The Clymer Service manual seems to show injecting the oil into a bolt that holds the brake disk in place.
Other videos show a "Filler" port on the top but with the shaft drive on the wrong side of the bike.
I have a 2008 RT. Where is the "IN" hole for the Final Drive oil?
Edit: Let me quess... You can't change the Final Drive Oil WITHOUT removing the rear wheel?
Thanks in advance.
Final Drive Oil Change
- Strat Tuner
- Has liked: 161 times
- Been liked: 32 times
- Strat Tuner(Yamaha FJR 2012)
- Willie Nelson
- Willie Nelson
- Strat Tuner
Re: Final Drive Oil Change
Chat GPT says....
I will go look again.
Here's the "back" of the Final Drive. Not helpful. the "back" of the Final drive unit, near the top, shows NO input port.
I'm beginning to realize one can't change the final drive oil without removing the rear wheel ... which is well beyond what I can do at home.
Shame on the engineer who designed that.
The rear face of the final drive? The mechanism seems to be round, but both faces of that circle face left and right... not back.Filling Procedure:
Locate the Fill Hole:
On the 2008 R1200RT, the fill plug is on the rear face of the final drive, near the top.
It’s a 6mm Allen/hex bolt.
- Willie Nelson
- Willie Nelson
- Strat Tuner
Found a video for a 2008 GS... my guess is the final drive units behave the same.
It's obvious, in the video, that you can't do this without removing the wheel! Astounding!!
I notice that this is "fixed" on later models, and that's as it should be.
Oh Well, I can have the mechanic change the Final Drive, Gear box, and clutch oil as well. Those are all separate items, I understand, and things I just can't do at home.
That's the price of owning a "vintage" ride.
Thanks for your attention.
Video Link is here : (as of 19 July 2025)
https://youtu.be/XiUI4fOdoJ8
------------------------------------- PS Edit: -----------------------------------------
I've ordered a quality Torque Wrench and plan to overcome my fear of R/R the
rear wheel!
rear wheel!
- Willie Nelson
- Willie Nelson
- Strat Tuner
related question
How many different liquids go into an R1200 RT (Hexhead)????
I'm trying to take good care of this venerable ride, and I'm confused about how many liquids I could replace IF I replaced ALL OF THEM.
(No coolant, I get that.)
How many different reservoirs need to be filled to keep this engine happy?
1. Engine Oil
2. Final Drive Oil
3. Brake fluid
Am I leaving something out?
1. Engine Oil
2. Final Drive Oil
3. Brake fluid
- Willie Nelson
- Willie Nelson
- Has liked: 126 times
- Been liked: 299 times
Re: related question
Gearbox oil. They like an alternator belt every now and again as well.Strat Tuner wrote: Sun Jul 20, 2025 7:00 pm How many different liquids go into an R1200 RT (Hexhead)????
1. Engine Oil
2. Final Drive Oil
3. Brake fluid
- Glenn
- Has liked: 77 times
- Been liked: 258 times
If replacing everything, then there is the oil in the clutch reservoir, https://www.bmwlt.com/threads/clutch-fl ... se.110106/
- Strat Tuner
Thank you, Glen. I'll add that to my list.
- Willie Nelson
- Willie Nelson
