Exhaust hanger on 2016 rt1200rt
Bearbike1
Post by Bearbike1 »
After servicing my bike the dealer handed me an exhaust hanger which was separated from the exhaust pipe.
It looks like it is located mid exhaust. Is the is necessary ?
exportman
Has liked: 16 times
Been liked: 75 times
Re: Exhaust hanger on 2016 rt1200rt
Post by exportman »
Hi
Do you mean the clamp between the exhaust flap valve and the silencer? This has a tendancy to seize so when you try to remove it the bolt sheers and you have to replace the clamp
Has liked: 35 times
Been liked: 183 times
exportman wrote: Fri Aug 29, 2025 9:39 pm Do you mean the clamp between the exhaust flap valve and the silencer? This has a tendancy to seize so .......
Indeed. This happened to mine at the last tyre change. The trye shop got it off, eventually, after much cursing & complaining and used a jubilee clip as a get you home bodge. I ordered a new one and put it on with a load of hi-temp grease on it, but I've added a remove, clean & regrease every Autumn & Spring to my 'in addition' maintence schedule. I kept the old one as I drilled the remains out, found a Stainless Steel nut & bolt that fitted, but now I know, hopefully won't need to use.
Silencer Clamp.jpg (32.62 KiB) Viewed 1245 times
exportman
Has liked: 16 times
Post by exportman »
Im still running with the bodge since I had a new rear tyre a month or so ago I will eventually get round to replacing it
