Removing Rocker Arms?
Has liked: 123 times
Been liked: 98 times
I have some valve/cam work coming up as soon on my 17RT, as the parts arrive. As I was looking through the maintenance manual, it doesn't explain removing the rocker arms. How does one remove those "needle rollers" that hold the rockers in place? I didn't even see a special BMW tool ;)
Anyone have any experience removing those little guys?
Re: Removing Rocker Arms?
From Adventure Rider for a 2018 GS, https://www.advrider.com/f/threads/repl ... s.1596611/
My wife says that I have man eyes and she may be right, but I sure don't see any little pins sticking out. I am guessing that those "bearing rollers" are just dowels and harder than the hinges of Hell. Something tells me that they are not going to just slide out without some sort of persuasion ;)
I hope that I am wrong
@Randyjaco does any of this lot help?
Rockers.pdf
(331.4 KiB) Downloaded 220 times
Replace Cams.pdf
(1.19 MiB) Downloaded 369 times
From BMWSportTouring for a 2015 RS, https://www.bmwsporttouring.com/topic/1 ... 00rs-2015/
"There is a pin that you pull out with your fingers, outward from the head. Then the shaft with the followers on it will just slide out."
Thank you, now it is starting to make sense. My parts are scheduled to arrive tomorrow :thumb: :cheers:
