Brake lever pivot
audibob2
Bike Model and Year: 2015 R1200rt
Been liked: 15 times
Brake lever pivot
Post by audibob2 »
I need to remove my Front brake lever pivot pin, on my 2014 R1200rt but it is very stiff.
Apart from removing the pivot nut, is there anything else I should be doing in order to remove the pivot so I can lubricate it. ?
Re: Brake lever pivot
I think from memory you have to unscrew the pin too
Been liked: 258 times
Take a look at the Normski video it may give you pointers he fits a ram mount to the clutch lever, it maybe the same for the brake.
audibob2
Post by audibob2 »
"I think from memory you have to unscrew the pin too"
Stu, do you mean the pivot pin is threaded?
I used a small clamp to move it so I am not convinced it is threaded through the housing. I did get my to move as far as the thread underneath is flush with the housing , but I cannot get the pin out any further.
Should I remove the lever assembly by removing the grub screw on the barrel and seperate it from the piston linkage.
I managed to get some WD 40 on the pivot pin, and push it down and tighten the nut again. The lever action is free, but I would like to know how to remove it correctly . On all my other bikes, the pivot pin just pulls out.
Are talking about the pin that holds the lever on or the one that pushes the brake piston?
audibob2
Post by audibob2 »
I am asking should I be able to remove the torx25 headed brake lever pivot bolt on it own, or do I need to remove the whole brake lever assembly including the span adjuster.
