I need to remove my Front brake lever pivot pin, on my 2014 R1200rt but it is very stiff.
Apart from removing the pivot nut, is there anything else I should be doing in order to remove the pivot so I can lubricate it. ?
Brake lever pivot
- Glenn
- Has liked: 77 times
- Been liked: 258 times
Re: Brake lever pivot
Take a look at the Normski video it may give you pointers he fits a ram mount to the clutch lever, it maybe the same for the brake.
audibob2
- Bike Model and Year: 2015 R1200rt
- Been liked: 15 times
"I think from memory you have to unscrew the pin too"
Stu, do you mean the pivot pin is threaded?
I used a small clamp to move it so I am not convinced it is threaded through the housing. I did get my to move as far as the thread underneath is flush with the housing , but I cannot get the pin out any further.
Should I remove the lever assembly by removing the grub screw on the barrel and seperate it from the piston linkage.
I managed to get some WD 40 on the pivot pin, and push it down and tighten the nut again. The lever action is free, but I would like to know how to remove it correctly . On all my other bikes, the pivot pin just pulls out.
- 20260304_084034[1].jpg (218.54 KiB) Viewed 1288 times
audibob2
I am asking should I be able to remove the torx25 headed brake lever pivot bolt on it own, or do I need to remove the whole brake lever assembly including the span adjuster.
