Bagster tank cover
Re: Bagster tank cover
Panman40 wrote: Sat Mar 07, 2026 7:40 pm I suffer with ocd so I had to find the best possible place to fix those straps :lol:
I do to a certain extent but after fecking up both panels(tabs)i wasn't keen on taking them off again.But in my defence(and I did start a thread exactly the same as owl's)I wasn't warned or told about those bloody tabs.It was an expensive lesson learned.Still,all worked out and everyone gets the protector on :thumb:
Has liked: 773 times
Been liked: 143 times
Just popped the panel off. Hopefully you can see where I put the strap on the right hand side. Also pic of the tabs to be careful of, basically remove 2 torx on tge inside of the panel at the front, pull out along the bottom until 2 poppers release and a small Velcro then gently lift the panel upwards , don’t pull it outwards as that when the tabs can snap.
owl
Has liked: 17 times
Been liked: 51 times
Post by owl »
That is above & beyond - thank you so much for doing that for me.
I have just spent the last hour trying to feed the strap down behind that panel and failed miserably - there's just not enough room.
Armed with your photos I will have another go either this afternoon or tomorrow morning.
owl wrote: Sun Mar 08, 2026 10:57 am That is above & beyond - thank you so much for doing that for me.
Once you’ve taken a panel off a couple times it literally takes 1 minute 👍, it was a similar place on the left side but not identical I don’t think. I’ve only removed the harness once since fitting it and that was to change an air filter.
owl
Has liked: 17 times
Post by owl »
I've got the offside strap done, thanks to those photos.
I have to get the bike out of the garage to do the nearside one, and it's raining now, so will try tomorrow.
