Fairing Tab Repair?
- Has liked: 123 times
- Been liked: 98 times
Fairing Tab Repair?
I just had the 2 plastic tabs on my right front side fairing pannel break. Other than buying a new pannel I am looking for a good secure fix for repairing the tabs. YouTube has several. Some don't look too strong. Anyone have a method that worked for you?
- exportman
- Has liked: 16 times
- Been liked: 75 times
Re: Fairing Tab Repair?
Hello
I found some stainless picture hooks that stuck on the back of the panels cant remember where from now it was on my previous RT
- Been liked: 560 times
Have a look here Randy.
viewtopic.php?t=6173
Do not rely on the double sided pads that come with them,mine melted in Spain and I had to bodge them to get home.Reinforce them like I did,they held on great after
You can make them yourself and save the money,but your not going to have to pay the price i did.
Hope it helps.
Hope it helps.
mikeromo73
- Has liked: 1 time
I used the Clearwater lights repair kit to fix mine and just found the double stick foam tape had come unstuck from the panel. I will remove and go back and "bodge" them with epoxy and fiberglass tape to reinforce them. I definitely like the way the panel goes back to looking normal and keeping the on/off process the same.
- Has liked: 96 times
- Been liked: 141 times
I recently used this JB WELD PLASTICWELD on my Triumph fairing. You cut off a slice of putty and mix it with the integrated hardener. I formed a small doughtnut around a fibre washer to strengthen the repair.
You have about 15 mins to work with it before it starts to harden. After 24 hours, it's rock hard.
https://www.jbweld.co.uk/copy-of-kwikwoodep-2
I fabricated a solution. I bent some 20 ga. stainless steel into a suitable shape and JB welded pieces to the pannel. They are strong and everything fits like stock. Here are some photos.
- Installed- top
- PXL_20260415_195723967.jpg (330.76 KiB) Viewed 1288 times
- Pannel instaulled 1
- PXL_20260415_195628392.jpg (409.15 KiB) Viewed 1288 times
- Bending Fixture
- PXL_20260414_141307726.jpg (380.79 KiB) Viewed 1288 times
